JD 4600 with 460 loader - loader control lever won't curl or dump
   / JD 4600 with 460 loader - loader control lever won't curl or dump #1
leadfarmer
Kubota L3400-MT, CAT 85J 955L, 44A D6B, 1937 R5 Gas Dozer
I have a JD 4600 with the 460 loader that had been sitting outside for several years without use. The loader will lift and lower but when I try to move the loader control lever side to side for the dump and curl it feels like it is locked. It hits solid resistance both ways. The control function lock lever below it is in the unlocked position. I will have to get under it and look at the linkage, but does anyone have experience with this issue?
   / JD 4600 with 460 loader - loader control lever won't curl or dump #2
Almost everyone suggest this. Check your QD's. Plug and unplug them to confirm they are engaged completely.
It was just stuck linkage. I made sure the valve was able to wiggle then I just muscled the control stick into moving side to side. Liberal application of Kroil and a thousand back-and-forths later it is now moving as it should.
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
