JD 4600 steering valve connection
   / JD 4600 steering valve connection #1
hills
murrells inlet, sc
jd 4600
Hi folks, I replaced the seal on the steering valve but when i replaced the unit i must have crossed up the lines. My bad. Does anyone know where I can see a drawing of the the connectons? John Deere is no help.
   / JD 4600 steering valve connection #2
Was the steering valve marked at the connections in any way that might help?
If you are not getting any steering I would swap the lines from the pump.
If it is steering right instead of left, I would swap the lines to the steering cylinder.
At least there are only four combinations.
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50322)
2018 Taylor-Dunn...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2011 Ford F-350 XL (A50120)
2011 Ford F-350 XL...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
