JD 4600 pto not working
   / JD 4600 pto not working #1
Hubertdavis71
John Deere 4600
I知 new to this form. Thanks for the add. I just got a 1999 model JD 4600 2wd from my dad. It had been sitting up for probably a year. When I got it cranked none of the hydraulic was working and it had a bad leak on the steering cylinder. I added some hydraulic fluid cranked it back up and it was milky so I drained all of it Then took the cylinder off and had it fixed. Bought a new inlet suction screen and external filter and put all new fluid in it. The bucket and rear hydraulics worked good but the rear pto still won稚 engage. The light is on and seat switch is jumped out. I turned the key on and pulled pto switch and climbed under the tractor and had 12v to the solenoid. So I pulled solenoid off thinking I would be able to pull the rod it sits on out but couldn稚 figure out how to get it out? I知 thinking the valve is probably stuck from the moisture ? Is the rod the solenoid sits on the valve? And if so how do I get it out? Or do I have to pull the whole block to get down into the valve? Sorry for all the questions. Any help and or pictures would be greatly appreciated!!!
   / JD 4600 pto not working #2
:welcome: to TBN
Are you working from a service manual?
No sir I have read the owner manual from cover to cover tho! Lol And I have YouTube and Googled and read every thing I could think of but I did not even think about a service manual 🤪. Thanks for the help
   / JD 4600 pto not working #4
Send a pm note to member "joecdeere" and see if he still has the service manual available that he could send to you. Include your email to him when you do. He has been very gracious with such help if he has the means.
Also, see the "similar threads" at the bottom of the page, as several have subjects that may be a good hit for you. As well, put your question in the "google search" box at the top of this page for more possibilities.
Might be good to know if you have HST or gear tranny.
2015 John Deere 544K Articulated Wheel Loader (A55973)
2015 John Deere...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2011 Chevrolet Malibu 2LT Sedan (A55853)
2011 Chevrolet...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
