JD 4600 HST PTO Problem
   / JD 4600 HST PTO Problem
**** Update ****
The electrical checks out 100% I followed the procedures in the tech manual to the letter.
A couple of things that I have noticed:
When raising the FEL the 3-point hitch will not operate and visa-versa.
When the engine is not on I can rotate the PTO shaft by hand
When the engine is on and PTO switch is either on/off I cannot rotate the PTO shaft at all.
Any one with ideas on what to check next?
   / JD 4600 HST PTO Problem #12
Not being familiar with the 4600 .....
Does it have both a mid PTO and rear PTO?
The reason I ask, is that on my 2520, there is a selector lever for engaging just the front PTO, just the rear PTO, or both.
If you have this type, have you tried the mid and/or rear PTO separately?
No I have only the rear PTO.
Any other thoughts? Do you have a FEL on your tractor?
Are there any HST Techs out there that could help me with this?
I don't mind going to the dealer but if it is something I can do myself...I'm not saying I want to or even could take apart a HST, just looking for an informed opinion on what I should be looking for.
Hey everyone!
Just to update you. I took the tractor into the dealer and the problem turned out to be corrosion of the PTO solenoid pin, due to moisture in the fluid.
The Tech. cleaned and reinstalled, (charged me two hours, fair I think) and all is fixed.
I'd like to say thank you to all who responded.
   / JD 4600 HST PTO Problem #16
I think a Tech is the only one who would have known to look there for problems. I am glad it is working, it is frustrating to have a broken tractor!!!!!
   / JD 4600 HST PTO Problem #17
I just wanted to thank kabeman for following up his post with what he found out. It's very nice when "problem" threads have the solution at the end.
2011 Kubota KX080-3 Midi Excavator (A55787)
2011 Kubota...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
Miller Spectrum 500 DC Plasma Cutting System (A55851)
Miller Spectrum...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
UNUSED 200 AMP 13' JUMPER CABLES (A54756)
UNUSED 200 AMP 13'...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
