JD 455 snowblower won't stay raised
   / JD 455 snowblower won't stay raised #1
John Deere 455
Hello, new JD owner here. I recently purchased a 455 with 575 hours on it, and I noticed the 47" snowblower attachment doen't stay raised: after a few minutes (5ish? Haven't timed it, but I'll notice it's lowered to the ground.). This is an issue because I'd like to raise it to a specific level when clearing snow off my gravel driveway, but lower it when clearing snow from my paved driveway.
I haven't changed the hydraulic oil and filter yet: will be doing that in a while.
Also: I can push the lower lever forward, and the blower will actually lift the front of the tractor up, but this doesn't happen on its own.
Edit: I just tested the mower deck, and it too drops after a few minutes. So I assume this is systemic.
Thanking you guys in advance.
   / JD 455 snowblower won't stay raised #2
Welcome to TBN
Lowers when tractor is running, or just when the tractor engine is turned off ?
Probably nothing wrong, just the way internal hydraulics is built/designed.
Maybe others have a better answer to offer.
   / JD 455 snowblower won't stay raised #3
I had the same setup in 2002.
That's the way they work, there's nothing wrong with it.
I used to watch the depth of the track that the front tire made, to judge how high/low the blower blade was.
2020 PETERBILT 567 DAY CAB (A53426)
2020 PETERBILT 567...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2008 GMC SAVANA 16' BOX TRUCK (A51247)
2008 GMC SAVANA...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
ABI TR3 LOT IDENTIFIER 134 (A53084)
ABI TR3 LOT...
