jd 455 pto solenoid problems
/ jd 455 pto solenoid problems #1
tinder
the wires to the pto solenoid burnt out due to overheating and after replacing the solenoid and valve the engine still cuts out as soon as i engage the pto.all fuses are ok and i wonder if there is a relay or anything else i should check out?
many thanks in advance
/ jd 455 pto solenoid problems #2
I'm not at all familiar with that system, but it sounds as if the mechanism that is engaged by the solenoid is frozen/partly frozen up. I suspect that it should freewheel when not engaged...needs some troubleshooting.
/ jd 455 pto solenoid problems #3
Welcome to the forum.
Check to see that the seat switch is hooked back up. It acts like that when it isn't, and it is easy to miss it (beenthere).
/ jd 455 pto solenoid problems #5
My problem might be "me" or firefox, but I couldn't get your link to load...
I also agree it sounds like the seat switch could be the problem.
/ jd 455 pto solenoid problems #7
What does the seat switch do? It sounds as if the pto fails to turn after a clutch is engaged by a solenoid, thereby killing the engine or, eventually, burning up the wiring.
/ jd 455 pto solenoid problems #8
If one is not in the seat, and the brake pedal is 'down', one can start the engine. But if you engage the PTO, while not in the seat, the engine will kill. So far, that is how you described the situation.
If you are in the seat, and the seat switch isn't hooked up, it is in the same configuration as you not being in the seat.
If you know the seat switch is functioning, then it is something else. But if the seat switch wasn't hooked up, that is what it could be. maybe, by chance, /forums/images/graemlins/grin.gif
it is not the seat switch and if i manually engage the pto by pushing in the valve spring it works fine
/ jd 455 pto solenoid problems #10
So, what is supposed to push in the valve spring?
/ jd 455 pto solenoid problems #11
There's got to be a "sending unit" type switch somewhere in the system that telegraphs to the seat switch that the PTO is engaged... perhaps that is where your problem is somewhere near the knob you pull to engage the PTO? I don't have a wiring diagram but you might try your dealer for help with a screen print off his computer? Good luck.
/ jd 455 pto solenoid problems #12
Do you have anything hooked up to the pto when you try it? It could be it is not hooked up properly,or it is binding.It also makes me wonder why the solenoid burned out in the first place.
/ jd 455 pto solenoid problems #13
Hey Tinder... did you find out what's causing the problem yet? Let us know!
/ jd 455 pto solenoid problems #14
where is the pto solenoid located on a 425 john deere
MASSEY FERGUSON 240 TRACTOR (A64278)
MASSEY FERGUSON...
2025 SDLANCH SDL2030GT Heavy-Duty Greenhouse Tent (A64194)
2025 SDLANCH...
2022 EZ-GO ELITE...
UNUSED JCT 96" PUSHER BOX (A65055)
UNUSED JCT 96"...
2017 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 INTERNATIONAL...
LOT OF TRANSPLANTER PARTS (A64278)
LOT OF...
