JD 455 injector pump problems
/ JD 455 injector pump problems #1
bdcord79
Nashville, TN
JD 455
I recently picked up a 92 JD455 GT and it has a bad injector pump. I am trying to get it removed so I can have it rebuilt, but the fuel rack is stuck in place and I can't get the pump up through the top. Any thoughts on how to get it up and out without damaging it worse?
I am new to diesels but am pretty good at the rest.
Ben C
/ JD 455 injector pump problems #2
:welcome: to TBN
Do you have the service tech manual to help in this endeavor?
I do have the service tech manual, but it does not give tips for moving the stuck fuel rack.
The manual is what helped me troubleshoot to this point. I just don't want to tear up any thing getting the pump out. I understand the ring gear to be in the way.
Ben C
/ JD 455 injector pump problems #4
If it has an electric shut off solenoid on it that screws into the side., remove it and go thru the hole, to knock the rack into the slot in the engine block.
You might just have to angle it enough to get a screwdriver on the rack.. your options are limited.
So I got the pump out without too much beating on the slide. Now where can I send it to have it rebuilt? I am in Nashville TN, the local JD service center doesn't do it in house. They recommended some places, but thought I would check here first.
/ JD 455 injector pump problems #6
I had sent you an email.. I can do it.. just put aol .com after my name.
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
