JD 455 Injection Pump Leaking on top
/ JD 455 Injection Pump Leaking on top #1
jcalla
Triangle, VA
I have added a 3-5lbs PSI inline fuel line pump to assist fuel getting to injection pump. Cleaned pick up screen on intank fuel pump. The leak is on the high pressure side, it should not be affected by supply side pressure. I have new OEM O ring seals for top fittings on order. I just replaced stock fuel pump 3 years ago. What do you think?
/ JD 455 Injection Pump Leaking on top #2
There is a copper crush washer under the dv holder along w the oring.. they’re a 1 time use..
The torque on the holder is 30 ftlbs..(very important)
Good luck
MAHINDRA 3650P TRACTOR (A60430)
MAHINDRA 3650P...
(2) 3"X24" HYD CYLINDERS (A60430)
(2) 3"X24" HYD...
Blue Diamond 103709 (A53317)
Blue Diamond...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
