JD 455 buying advice please
/ JD 455 buying advice please #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
I'm looking at buying a John Deere 455 with rear 3PL and PTO fitted.
Price is $NZ6500 (about $US4500).
You can see pictures online here : John Deere 455 | Trade Me
Intended use is :
Replace my Kubota F1900 4WD 60" mower
Replace Kubota B2150 tractor used with tow hitch for moving trailers
Replace Iseki SG15 mower (which doesn't get used)
Provide hydraulic flow to a McHale 995LM bale wrapper
I've checked the hydraulic flow requirements and it should run the wrapper ok (needs 6L/min @ 60 Bar)
Questions :
Will I be disappointed with the mowing performance compared to my F1900 ?
Can it lift 300kg (600 lb) on the rear 3PL ?
Are there any weak parts in the 455 design that I should look at on this particular machine before buying ?
Thank you
/ JD 455 buying advice please #2
Rock solid tractor.. and mowing is what I find it does best, and not less than other chores.
IMO, the 455 is better than any other model (edit: of lawn/garden ) Deere has produced since.
(..and agree with CADplans, and might be best to add a PTO hyd. pump, as the PTO will run on continuous basis)
/ JD 455 buying advice please #3
The 455 is still a GT,, with hydraulic flow being supplied by a hydrostatic transmission charge pump,,,
rather than an actual gear pump.
The flow is intended for occasional use, like steering, and mower lift,, not continuous use.
It is a great garden tractor,, maybe not the replacement for the multitude of machines you list,,,:confused2:
So it's not going to run my wrapper for 6 hours continuously.
Is the PTO rated for high duty cycle or is it also expected to be occasional use only ?
Caterpillar 906M (A53317)
Caterpillar 906M...
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2014 JCB 930 (A53317)
