JD 4520 Losing power in C range
   / JD 4520 Losing power in C range #1
rjm5133
S.E. PA
5-John Deere 855's, 2155, 2555,5520, 2-5075e's 4520, 1070, 2720, 4-kubota ZD331, M7040
i have a jd 4520 with 600 hours on it. runs strong in A and B range but has no power in C. it used to go down the road at 15 or 16 mph now runs at 10 tops and slows to 4 or 5 mph on the slightest incline. engine never blogs down more than a hundred rpms and like i said runs fine in A and B and has plenty power in the loader and 3pt hitch
any one else have this problem or have any idea what the issue could be.
any help is much appreciated
   / JD 4520 Losing power in C range #2
Turn off the Load Match feature (your operator manual should describe how to do that) and see if performance improves. If it does, then I would suspect the throttle sensor may be out of adjustment.
   / JD 4520 Losing power in C range #4
Had similar issue on my 4520. My issue was the pressure that drives the hydraulic clutches. (power rev) Dealer shop adjusted it and all better now. It would slip in c or if I was digging into a pile with the fel.
Attached is a drawing of the clutch circuit.
   / JD 4520 Losing power in C range #5
Is it stuck in 4wd? I would also check the load match setting like suggested before. My 3320 would keep the RPMs up and the tractor would slow down. It keeps you from lugging the engine. I added the cruse control option so you didn't have to go through button pushing to turn the load match on and off.
Dan
   / JD 4520 Losing power in C range #6
Did you ever get this resolved?
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A53422)
2008 Ford F-250...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
