JD 4520 Losing power in C range
   / JD 4520 Losing power in C range #1
rjm5133
S.E. PA
5-John Deere 855's, 2155, 2555,5520, 2-5075e's 4520, 1070, 2720, 4-kubota ZD331, M7040
i have a jd 4520 with 600 hours on it. runs strong in A and B range but has no power in C. it used to go down the road at 15 or 16 mph now runs at 10 tops and slows to 4 or 5 mph on the slightest incline. engine never blogs down more than a hundred rpms and like i said runs fine in A and B and has plenty power in the loader and 3pt hitch
any one else have this problem or have any idea what the issue could be.
any help is much appreciated
   / JD 4520 Losing power in C range #2
Turn off the Load Match feature (your operator manual should describe how to do that) and see if performance improves. If it does, then I would suspect the throttle sensor may be out of adjustment.
   / JD 4520 Losing power in C range #4
Had similar issue on my 4520. My issue was the pressure that drives the hydraulic clutches. (power rev) Dealer shop adjusted it and all better now. It would slip in c or if I was digging into a pile with the fel.
Attached is a drawing of the clutch circuit.
   / JD 4520 Losing power in C range #5
Is it stuck in 4wd? I would also check the load match setting like suggested before. My 3320 would keep the RPMs up and the tractor would slow down. It keeps you from lugging the engine. I added the cruse control option so you didn't have to go through button pushing to turn the load match on and off.
Dan
   / JD 4520 Losing power in C range #6
Did you ever get this resolved?
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
1261 (A50490)
1261 (A50490)
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
