JD 4520 compact tractor [2004] engine surges
   / JD 4520 compact tractor [2004] engine surges #1
Crankygranke
Engine surges like fuel starving momentarily then comes back and repeats. this happens at all speeds. any time under load is worse. I've replace filters, fuel and trans. It's a power reverser. replaced fuel lines, cleaned fuel tank, replaced the transfer pump, air filters. 1800 hrs on tractor. Starts fine, no smoke and does not miss. Any help will be appreciated. thanks
   / JD 4520 compact tractor [2004] engine surges #2
There is a spring on the throttle shaft that break and/or get worn..
Make sure there is a solid connection between the pump throttle & the linkage, no slop.
If u could provide some pump #'s off the tag, that would be most helpful.. JD put several diff. pumps on that tractor.
   / JD 4520 compact tractor [2004] engine surges #3
Just had the same problem with my JD 5320, it had some sort of sludge in the tank (looked like half dried silicone) it would suck it into the line and would starve motor of fuel
each injector has it's own pump. all in the head. no external pump. linkage is fine
i cleaned the tank and the screen at the out flow. a little dirty but all clean now.
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
Club Car Electric Utility Cart (A55853)
Club Car Electric...
2014 Chevy Malibu (A56859)
2014 Chevy Malibu...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
BOMAG SMOOTH DRUM ROLLER (A58214)
BOMAG SMOOTH DRUM...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
