JD 4520 2005yr
   / JD 4520 2005yr #1
willy16
jd 4520 built 2005
Question about the hyd pump located on the right side of the engine. It appears to me to have 2 pressure outlets.
One for the FE loader & one for the power steering. I'm I correct on this assumption? I hope I've given enough correct info. Thanks in advance.
   / JD 4520 2005yr #2
You are correct about the lines. It is a tandem pump setup.
ExMark Quest Zero Turn Mower (A50860)
ExMark Quest Zero...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2013 Dodge Grand Caravan SXT Van (A48082)
2013 Dodge Grand...
2023 Ford Explorer SUV (A48082)
2023 Ford Explorer...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
