JD 450G rear pin on Angle Cyl seized cant remove
   / JD 450G rear pin on Angle Cyl seized cant remove #1
widetractman
Ms.
I am trying to remove rear locking pin on the Angle Cyl. to get it out to replace lub line to C Frame The pin is seized in the self centering bushing and the spacers on both sides. I have a 4 ton porta power between the C Frame trying to push out the pin, but no go. I though about cutting the spacers with a air chisel, as their is room, maybe then the porta power would push out the pin with a little heat. If that does not work, is it possible to crack the bushing? What do the pro mechanics do when they incounter this problem.
   / JD 450G rear pin on Angle Cyl seized cant remove #2
If you have the time make you a big punch the same diameter (or close to it) of the pin in the shape of an L or T (weld) that you can strike with a sledge hammer.
Make yourself a long handle so the person holding the T or L can be well out of the way of the sledge hammer.
Safety glasses and gloves a must have.
And Knock the crap out it she will move!! Haha
DAVID,
CAT Skid Steer (A50322)
CAT Skid Steer...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
40' shipping container (A52377)
40' shipping...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
