JD 450G rear pin on Angle Cyl seized cant remove
   / JD 450G rear pin on Angle Cyl seized cant remove #1
widetractman
Ms.
I am trying to remove rear locking pin on the Angle Cyl. to get it out to replace lub line to C Frame The pin is seized in the self centering bushing and the spacers on both sides. I have a 4 ton porta power between the C Frame trying to push out the pin, but no go. I though about cutting the spacers with a air chisel, as their is room, maybe then the porta power would push out the pin with a little heat. If that does not work, is it possible to crack the bushing? What do the pro mechanics do when they incounter this problem.
   / JD 450G rear pin on Angle Cyl seized cant remove #2
If you have the time make you a big punch the same diameter (or close to it) of the pin in the shape of an L or T (weld) that you can strike with a sledge hammer.
Make yourself a long handle so the person holding the T or L can be well out of the way of the sledge hammer.
Safety glasses and gloves a must have.
And Knock the crap out it she will move!! Haha
DAVID,
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2015 CHEVROLET SILVERADO 2500HD (A53843)
2015 CHEVROLET...
1994 Utility Trailer MFG Co. VS2R Van Trailer (A53117)
1994 Utility...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
