JD 450c Steering Question
/ JD 450c Steering Question #1
DirtyWorks
Mississippi Pine Belt
ASV RC-100, '07 272c Cat ,Kubota 080 with Cimaf Head, Cat 257 MTL, JD 450c, Kubota 3440 4wd CUT w/ fel
Hi guys, as you may know from previous posts I have a John Deere 450c Dozer. It has a LOT of hours on it and recently (last few months) I have noticed that the steering on the right is weaker than on the left ( lever steer). This thing really wears you out after a few hours:eek:
Any suggestions on the adjustment? It has wet clutches and I've heard that I need to check the pressure?
I also need to know the year SN 199975T.
and while I have your attention:rolleyes: mabey a shove in the direction of a FREE online downloadable maintenance manual on the old iron:D as money is always an object in this house!
Thanks for any and all coments in advance!
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 Ford F-150 Crew Cab Pickup Truck (A59230)
2019 Ford F-150...
207279 (A52708)
207279 (A52708)
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
