JD 450B Dozer Transmission repair
   / JD 450B Dozer Transmission repair #1
DozerDon
John Deere 450B Dozer
I recently replaced the front pressue seal on the transmission pump. The input shaft is grooved (scored) from previous seals.
During this repair I removed the bushing, shaved .060 thousands of an inch and relocated the seal on the shaft.
Tractor ran but seems to be leaking again though not like before. Looses about 3 gallons of transmission fluid over 5 hours.
Going to disassemble again. Does anyone have any suggestions if the seal is again leaking? One idea may be to apply a redi-sleeve. All I know at this point is that it is leaking from the bottom of the bell housing area.
I appreciate any assistance or advise.
It is a nice 65 vintage.
   / JD 450B Dozer Transmission repair #2
Good luck with your repair. Do you have any pictures? We love pictures here on TBN:thumbsup:
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
Kubota RTV500 (A47384)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55218)
Neckover GL24-2-7K...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
