JD 4500
   / JD 4500 #1
mikedeere
I read these threads all the time, but I don`t see much about the 4500. Does this mean that they don`t have many problems?? I have a 4500, haven`t had too much problem except sometimes in the cold it won`t start.
   / JD 4500 #3
I have a 1999 4500 which has been virtually bullet-proof. The only two issues I have had is battery replacement which I solved 5 years ago with a Delco Freedom Battery. The second is a sensitive safety switch which requires moving the reversing lever slightly when starting.
It has been a great tractor.
Randy
   / JD 4500 #4
I have a 2000 4500 and I've had no issues with it, other than battery corrosion, you'd think deere would put better batteries on their tractors. 650hrs and counting...
   / JD 4500
Thanks for the responces. I also had the battery thing but for the most part I haven`t had anything major go wrong. For the way I run it thats a miracle.
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
1986 VIM TACK TANKER TRAILER (A50854)
1986 VIM TACK...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
