JD 4500 3rd SCV
   / JD 4500 3rd SCV #1
MMH
Murrysville, PA
JD 4500
I have a John Deere 4500 with a 3rd Selective Control Valve (SCV). I just got a grader blade w/ a cylinder & finally will use the 3rd SCV. Is there a standard type hydraulic fitting for the JD SCV? I need to know so that I get the correct hydraulic hoses made up.
   / JD 4500 3rd SCV #2
I believe the QD on the FEL should fit the 3rd SVC. Your local JD dealer should be able to help you out though. Good luck. Roger
   / JD 4500 3rd SCV #3
AM105467 is the male tip, is 1/2 orb threads. Deere did not change full size compacts to the industry std 1/2" iso tip until partway through 20 series production.
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
Alamo SH88 88" 3pt Flail Mower (A50774)
Alamo SH88 88" 3pt...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Swict 66" Skidloader Bucket (A50774)
Swict 66"...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
