JD 448 backhoe problem
/ JD 448 backhoe problem #1
doppler46
Central Texas
JD 4310 JD448 backhoe attachment, Farm Trac 60, John Deere 5055
I have a JD 4310 with the JD 448 Backhoe attachment. Everything except the dipper works good. The dipper goes up and will lift but when I lower it just free falls slowly and will not apply downward pressure. It is not applying a load on the motor or hydraulics. Any suggestions?? Thanks!
/ JD 448 backhoe problem #2
The dipper
Do you mean the Boom ?
Are you pushing the stick too far and going into 'float' mode ?
Not the boom. Based off the picture you posted it is the stick. My manual calls it a dipper. I tried just partially moving it and all the way with the sane results. When I lift it it puts a load on the tractor like normal. When I go to lower it just free falls and will not apply any down pressure. I asked the dealer today and he said swap the cylinder with te boom cylinder and see if I have the same fault. At least he did tell me he has not had many problems with the backhoe in the past. I cannot see it being a cylinder problem. There are no leaks and I do not hear fluid rushing as if it is bypassing some where in it. I am thinking valve body but I have never taken one apart.
Anyone have the hydraulic Schematic for the backhoe?
/ JD 448 backhoe problem #6
Did you buy used or new? If new -- call dealer.
If used, you probably have a blown out seal on the dipper stick cylinder or a worn control valve or the bypass on that circuit is stuck open.
I bought it new 3 years ago. I have dug hundreds of cedar stumps with. I think I am going to swap the lines with the spool valve next to the one that is not working and see if the problem changes. The dealer said to swap the boom cylinder with the dipper cylinder. I think it will be easier the other way. Thanks!
/ JD 448 backhoe problem #8
I have seen a hundred cylinder problems for every one valve problem. I would bet it's a blown piston seal.
Okay tonight I swapped the hoses on the dipper cylinder to see if the fault would change. When I swapped the lines on the cylinder I had down pressure but it would not lift up. So the fault did change. So it is not the cylinder. I then decided to take the spool valve shaft out and see if there was any damage. The shaft looked good and so did the valve body. I put it back togeather and still the same problem it would not appy down pressure. I took the lower hose off the cylinder and held it in a bucket and started the tractor. With out activating the lever I had a steady flow of fluid coming out of the hose. When I activate the lever the same amout of fluid came out and I could put my finger over it and stop the flow. I then took the other line off and with the tractor runnin there was no fluid flowing. When I activated the lever it had good strong pressure.
So the question now is can it be the pressure relief valve that is causing the problem? Has anyone taken the pressure relief valve apart before? I did not think so since it should be part of the lift portion of the dipper also. But I am doing this by trial and error. Any suggestions??
/ JD 448 backhoe problem #10
Doppler46:
First, I am not a JD guy and only an amateur at hydraulics. But I have a couple of suggestions:
1.) Post this on the Hydraulics board, I think you will find more help there.
2.) If the earlier refernced diagram is a diagram of the boom, dipper or sick, and bucket curl parts of your valve (not sure what happened to swing) I would be mighty suspicious of the load check valves, as opposed to the relief valve. If the relief valve were bad, normally one for the entire valve body, if seems like all the valves in the body would have a problem. But the load checks are, in essence, relief valves for individual cylinders . I suspect, if you have load checks, the one for the dipper cylinder is either stuck or has a broken spring in it. Now, in terms of taking it apart, diagnosing and fixing it, this is one place the folks over on the hydraulics page could really help.
Hope this helps. Best of luck.
/ JD 448 backhoe problem #11
I'm not a JD guy either, but I do have a lot of experience with hydraulics.
I looked up the 448 backhoe at the JD parts site and the parts manual shows that the dipperstick valve section does have an individual port relief for one port. This port relief acts independently and seperately from the main relief. The port relief only relieves its particular port and is therefore set lower than the main relief which regulates the pressure to all the ports.
It sounds to me like you have a bad port relief. You can test to see if it's the port relief in several ways. One of those ways is by swapping the port relief from the stick section with the port relief from the boom section. If the port relief is bad, the problem will follow it to the boom section.
Please use standard safety practices and make sure nothing can fall on you or others because when you remove the port relief there is nothing left to hold the oil flow back and if the boom is up and not supported it will come down. INSTANTLY!!!
Hope you get this sorted out soon!
Mark
Okay Tradermark I now see what you were saying. I found a link that shows the valve broken down. The difference between the dipper and the boom relief valves are that the relief valve is mounted on top of the dipper valve. The boom relief valve is located on the bottom of the boom valve. The part numbers are the same so I will swap them tomorrow after work or Saturday, time permitting. Either way I will post a response. I hope it will be a postive one. Thanks!
Finally fixed. I removed the pressure relief valves from the boom and the dipper control valves. The dipper relief valve was stuck and would not move. I took it apart and there was a piece of looked like rubber wedged between the rubber piston rings. I cleaned it up oiled it and reassembled it. Works like new. Cost of repair zero dollars and I like that! he pressure relief valve from the dealer is 290.83. Dug two trenches this morning with it. I have had the backhoe for 3 years and it sure does come in handy. Thanks for all the help!!
2014 Ford Escape 4WD SUV (A61574)
2014 Ford Escape...
Pallet of Safety Cones (A64047)
Pallet of Safety...
2012 WESTERN STAR 4900 SB MID-ROOF SLEEPER (INOPERABLE) (A63569)
2012 WESTERN STAR...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
Ripper Tooth Excavator Attachment (A61572)
Ripper Tooth...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
