Backhoe JD 448 Back Hoe on a 4720 with Cab
   / JD 448 Back Hoe on a 4720 with Cab #1
rdp58
Morristown Tn
JD 3320 and JD 4720
Has anyone put a 448 back hoe on a 4720 with a cab? One JD dealer said it would fit and another dealer said it would not. Does any one have or know where to get the brackets (other than the dealer) for the hoe that fits the 4000 series? Thanks for your response.
   / JD 448 Back Hoe on a 4720 with Cab #2
The 448 fits the open station 4720 so the question is related to the Cab configuration not the series. Have the dealer who said it wouldn't explain to you why, then have the dealer who said it would fit explain what issues or challenges you may encounter. May need to go back and forth with questions until you get your answer.
I continue to hear that a frame attachment is preferred over a 3-point attachment. Know what you are getting in terms of attachment.
   / JD 448 Back Hoe on a 4720 with Cab #3
Check the Private Party Ads - there is a 448 BH off a 4720 there.
   / JD 448 Back Hoe on a 4720 with Cab #4
The 448 and 485 hoe are the same. Look at the parts site and you'll see that. So if the 485 will fit on cabbed 4000 machines it must be a different bracket arrangement. I'm fairly sure it could work with a 448.
Matt
2015 Kenworth T880 (A55973)
2015 Kenworth T880...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
