Backhoe JD 448 Back Hoe on a 4720 with Cab
   / JD 448 Back Hoe on a 4720 with Cab #1
rdp58
Morristown Tn
JD 3320 and JD 4720
Has anyone put a 448 back hoe on a 4720 with a cab? One JD dealer said it would fit and another dealer said it would not. Does any one have or know where to get the brackets (other than the dealer) for the hoe that fits the 4000 series? Thanks for your response.
   / JD 448 Back Hoe on a 4720 with Cab #2
The 448 fits the open station 4720 so the question is related to the Cab configuration not the series. Have the dealer who said it wouldn't explain to you why, then have the dealer who said it would fit explain what issues or challenges you may encounter. May need to go back and forth with questions until you get your answer.
I continue to hear that a frame attachment is preferred over a 3-point attachment. Know what you are getting in terms of attachment.
   / JD 448 Back Hoe on a 4720 with Cab #3
Check the Private Party Ads - there is a 448 BH off a 4720 there.
   / JD 448 Back Hoe on a 4720 with Cab #4
The 448 and 485 hoe are the same. Look at the parts site and you'll see that. So if the 485 will fit on cabbed 4000 machines it must be a different bracket arrangement. I'm fairly sure it could work with a 448.
Matt
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
Lot (2) HD 10' Pipe Gates (A50515)
Lot (2) HD 10'...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
Detach Trailer (A50514)
Detach Trailer...
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
