JD 4430 smoke source
   / JD 4430 smoke source #1
cdupuy
Waco, TX
MF 135, John Deere 4430
I have a 1975 jd 4430 diesel tractor that is new to me. After start up, I notice smoke coming out of a tube that is located between the frame and the battery box on the right side of the tractor. The tube is pointed straight down. Is this some a breather tube for crankcase oil? Thanks, Carr
   / JD 4430 smoke source #3
cdupuy
Yes as other poster stated tube you refer to is engine crankcase breather tube. I've seen engines have blow-by without using a lot of oil between oil changes. Colder ambient temps can cause more blow-by to appear. Have you checked PH of engine coolant?
Thanks for the replies. Tx Jim, I have not checked the ph of the engine coolant. I will check it out. Thank you.
   / JD 4430 smoke source #5
My 2030 (which does not get used hard), has a lot of blowby, not smoke, just air that blows hard enough to stir up the dust on the ground. When used hard, the blowby goes away for a while.
2018 Dodge Journey SE SUV (A50860)
2018 Dodge Journey...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2011 Ford Expedition XLT SUV (A48082)
2011 Ford...
2015 Ford Explorer AWD SUV (A48082)
2017 International DuraStar 4300 Cab and Chassis Truck (A48081)
2017 International...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
