jd 4430 power shift, hydraulic questions
   / jd 4430 power shift, hydraulic questions #1
markmc60
Palmer Texas
JD4430,Ford 600, cub, JD400 backhoe, JD450 dozer, Cat 913 motor scraper, Allis Chalmers D grader
morning, hoping to get some help and advice.
I have a 4430 that I spoke with a couple folks on here that has helped me a lot, so I say thanks, still figuring out an issue with my shifting and I have been building a hydraulic pressure test kit.
just about have all the pieces for this 4430. but here is my question.
I recently acquired a Koyker 565 loader(bartered $0 invested), and I have been looking for a remote joystick and valve, looked thru the forums here and got some hints, went to surplus center and I can build my system for about $650.
short of the hoses and NOW for the big question.......... where do I "tap" into the hyd pressure and return for my valve?
I found a thing like this John Deere Tractor Tools - Macon Precision Machining LLC power beyond kits that mount behind the selective control valve.
any suggestions?
   / jd 4430 power shift, hydraulic questions #2
To access hyd's for joystick valve one has 2 choices. You can TEE into junction block(key 24A or 24B) on RH side middle of tractor for pressure & return oil to sump or ported hyd filter cover. When I had a JD 158 FEL on my JD 4255 I teed into junction block on RH side & returned oil to trans sump & loader operated just fine for handling rd bales. Another option is acquiring a PBY block you refereed to. I think you'll find a ported hyd filter cover with the correct length bolt won't be easy to locate/acquire
guys I fixed a few leaks and apparently made the durn tractor made, it seems to have changed symptoms.4430 hyd 1.jpg4430 hyd 4..jpg4430 hyd 6.jpg4430 leak.jpg4430 side.jpg
I was trying to attach my gauges and get a reading following the service manual. but of the 30 o-ring adapters I have I did not have a single 3/8 o-ring to fit in that block with the 2 hoses. according to my manual that is straight off the front hyd pump.
now you see the pic with the suction delivery pipe is off, I had a major hyd oil leak there and according to my service manual that supplies my trans pump.
I posted all these pictures for reference, 1 shows the make shift cup for the filter!, thats the things I am working with.
I did put a test gauge in SCV and max pressure I have is 1750, now I did not add a drop hose to the other side and route it into my hyd fill tube.
I cant give good test numbers yet until I get the correct 3/8x24 o-ring fitting.
my symptom is when I start the tractor my steering or brakes, very slow to respond and my steering goes away while driving it, I stop and rock the wheel it builds back, I will get the fittings and run the hyd test by the book and see where that goes,
I have noticed a leak in the pic of the clutch and pto, not sure where it is coming from, I also notice some oil on the floor between my feet, not a lot, but I pulled the panels and dash cowl there is a leak between the steering column and the bottom, Ill look up the parts and list them.
just an update............the one thing I dont have is ............ experience on a john deere 4430............. but I'm working on that
this is a list of the fittings for John Deere, seems to be all you need and where I got them.test fitting list.jpg
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
UNUSED RAYTREE QUICK ATTACH POWER RAKE BUCKET (A50460)
UNUSED RAYTREE...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
2017 JLG G5-18A Telehandler (A50490)
2017 JLG G5-18A...
1991 Deere 750B Long Track Crawler Dozer (A50860)
1991 Deere 750B...
2023 Kenworth T880 Truck, VIN # 1NKZLP0X5PJ250342 (A48836)
2023 Kenworth T880...
