3-Point Hitch JD 4410 Rockshaft Will Not Lift
   / JD 4410 Rockshaft Will Not Lift #1
andmfg
Blowing snow for the first time this year and almost done when I couldn't raise the rockshaft arms. I have had a very small oil leak over the past summer so I checked the oil level and it was a gal low so I filled it. No luck with the rockshaft arms. All other hydraulics work great. Looking at the manuel I note two other things to check: the rockshaft control valve filter and the oil suction screen and filter. Any one have this problem. What should I look at first and how did you fix this problem?
   / JD 4410 Rockshaft Will Not Lift #2
I've never had to replace the rockshaft control valve on either of my JD's.
However, I have cleaned the suction screen and replaced the hydraulic filter's - that's just required maintainence.
Have you tried to adjust the rockshaft drop/stop valve that's located at the base of the tractor seat between your legs? I'd open the valve up as far as possible (with a load on the 3pt arms - rear blade, etc.) and with the engine at a fast idle; run the 3pt lever up and down - cycle the 3pt.
If your other hyd functions are working correctly - loader and steering - it's not likely the suction screen or the hyd filter that's the problem.
More likely, the problem would be either the rockshaft control valve or the rockshaft lift cylinder.
AKfish
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2001 John Deere M665 (A50120)
2001 John Deere...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
