3-Point Hitch JD 4410 Rockshaft Will Not Lift
   / JD 4410 Rockshaft Will Not Lift #1
andmfg
Blowing snow for the first time this year and almost done when I couldn't raise the rockshaft arms. I have had a very small oil leak over the past summer so I checked the oil level and it was a gal low so I filled it. No luck with the rockshaft arms. All other hydraulics work great. Looking at the manuel I note two other things to check: the rockshaft control valve filter and the oil suction screen and filter. Any one have this problem. What should I look at first and how did you fix this problem?
   / JD 4410 Rockshaft Will Not Lift #2
I've never had to replace the rockshaft control valve on either of my JD's.
However, I have cleaned the suction screen and replaced the hydraulic filter's - that's just required maintainence.
Have you tried to adjust the rockshaft drop/stop valve that's located at the base of the tractor seat between your legs? I'd open the valve up as far as possible (with a load on the 3pt arms - rear blade, etc.) and with the engine at a fast idle; run the 3pt lever up and down - cycle the 3pt.
If your other hyd functions are working correctly - loader and steering - it's not likely the suction screen or the hyd filter that's the problem.
More likely, the problem would be either the rockshaft control valve or the rockshaft lift cylinder.
AKfish
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
