JD 4410 MFWD problems
   / JD 4410 MFWD problems #1
welder83
john deere 4410
Hello
I bought a 4410 with 1500 hrs . The mfwd doesn't work. The switch works and the cylinder that actuates the cross shaft moves if it痴 unpinned from the cross shaft . However the cross shaft will not rotate . Any help would be greatly appreciated!!
Thank you
   / JD 4410 MFWD problems #2
I have a PDF of the technical manual for your tractor, if wanted, message me, or email me and it’s on the way
Joe
   / JD 4410 MFWD problems #3
Maybe the cross shaft is frozen try some penetrating oil on it...........:2cents:
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A51039)
2006 Magnolia Dry...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A50854)
2009 UTILITY...
