JD 4410 Hydraulic Pump Rebuild
   / JD 4410 Hydraulic Pump Rebuild #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I was looking at the parts breakdown and I was wondering if anyone knows if the seal kit does both pumps or just one? The diagram notes the parts for both pumps with an (A), but when I googled the kit number, and Amazon has it and shows only one set in the picture. I'm not sure if I need 1 set or 2? Same for the bushing kit.
LVA10948 Seal Kit
LVA10949 Bushing Kit
   / JD 4410 Hydraulic Pump Rebuild #2
I was taught years back while 1st employed at a JD dealership selling parts to "always read parts footnotes and descriptions". Note this disclaimer (INCLUDES PARTS MARKED (A). This should answer your question. Read the amounts of each part numbers in the kit.
LVA10948 Seal Kit 1 (INCLUDES PARTS MARKED (A))
3 ...... Seal 1 (A) SHAFT
4 ...... Seal 2 (A)
5 ...... Seal 2 (A)
21 ...... Seal 2 (A)
22 ...... Seal 2 (A)
23 ...... Back-Up Ring 2 (A)
6 ...... Back-Up Ring 2 (A)
Yeah, except all the pictures of the kit I've seen only show 1 set for 1 pump. I would rather not have to place an order twice, but I guess I'll find out which is right soon enough.
   / JD 4410 Hydraulic Pump Rebuild #4
You need one kit for each pump for a total of 2 kits.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
20626 (A51691)
20626 (A51691)
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
2018 FORD EXPEDITION (A51406)
2018 FORD...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
