JD 4410 Hydraulic Pump Rebuild
   / JD 4410 Hydraulic Pump Rebuild #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I was looking at the parts breakdown and I was wondering if anyone knows if the seal kit does both pumps or just one? The diagram notes the parts for both pumps with an (A), but when I googled the kit number, and Amazon has it and shows only one set in the picture. I'm not sure if I need 1 set or 2? Same for the bushing kit.
LVA10948 Seal Kit
LVA10949 Bushing Kit
   / JD 4410 Hydraulic Pump Rebuild #2
I was taught years back while 1st employed at a JD dealership selling parts to "always read parts footnotes and descriptions". Note this disclaimer (INCLUDES PARTS MARKED (A). This should answer your question. Read the amounts of each part numbers in the kit.
LVA10948 Seal Kit 1 (INCLUDES PARTS MARKED (A))
3 ...... Seal 1 (A) SHAFT
4 ...... Seal 2 (A)
5 ...... Seal 2 (A)
21 ...... Seal 2 (A)
22 ...... Seal 2 (A)
23 ...... Back-Up Ring 2 (A)
6 ...... Back-Up Ring 2 (A)
Yeah, except all the pictures of the kit I've seen only show 1 set for 1 pump. I would rather not have to place an order twice, but I guess I'll find out which is right soon enough.
   / JD 4410 Hydraulic Pump Rebuild #4
You need one kit for each pump for a total of 2 kits.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
LANESHARK LS2 LOT NUMBER 159 (A53084)
LANESHARK LS2 LOT...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2023 UNVERFERTH 632 LOT NUMBER 178 (A53084)
2023 UNVERFERTH...
Electric Concrete Mixer (A51573)
Electric Concrete...
