JD 4410 eHydro brake sticks
   / JD 4410 eHydro brake sticks #1
When I push the brakes on my dad's 4410 it brakes but doesn't release after you let go of the brakes. The pedals will come up but the brakes don't release. A friend of mine had a 4310 doing the same thing so he told me to get underneath the tractor with a hammer and knock the brake back. It works but that gets old like really quick. Is there a place to grease it or what really is the problem? Did any of you have a problem with the brakes on the 4310 ,4410. How can it be fixed? Thanks
   / JD 4410 eHydro brake sticks #2
I too had a 4310 with the same problem. Mine was because of salt damage.
I took off the brake linkage and springs and liberaly applied PB Blaster to the shaft going into the housing. I then moved the lever back and forth till it loosened up. Hope this will help.
Thanks for the info. I will try that to night. thanks
   / JD 4410 eHydro brake sticks #4
Our 3520 does the same thing...this should not happen to a 1 year old machine?:(
   / JD 4410 eHydro brake sticks #5
Yes, the linkages get tight and the shafts going into the axle housings get grit in them or rusty. Clean and lubricate each side.
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
20357 (A55758)
20357 (A55758)
2019 Ford F-450 12ft Flatbed Service Truck (A55788)
2019 Ford F-450...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
20714 (A55853)
20714 (A55853)
