JD 4400 Wet Disc Brake Problem
/ JD 4400 Wet Disc Brake Problem #1
jtette
Western New York
2000 JD 4400
I have a new JD 4400 tractor. The brakes hang up and the pedal is very stiff. I've done car brakes before, but never heard of wet disc brakes before. Does anyone have any experience here they would be willing to share? Thanks.
/ JD 4400 Wet Disc Brake Problem #2
Carefully examine all external linkages and pivots. Chances are greater that the problem is external than internal, unless you are using an incompatible or water-laden oil in your transmission/hydraulic system.
/ JD 4400 Wet Disc Brake Problem #3
My friend has a 4400, and has had problems with the brake return springs breaking, Very easy fix.
After some playing with the tractor, it seems that they work fine after she warms up.
2021 Ford F-250 Pickup Truck, VIN # 1FT7W2BT4MED85586 (A61165)
2021 Ford F-250...
2006 Vermeer BC1000XL Chipper (A61166)
2006 Vermeer...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
New Holland Workmaster 25S Tractor/Mower (A61166)
New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
