jd 440 rear axle housing replacement??
   / jd 440 rear axle housing replacement?? #1
yougotobekidinme
benton arkansas
4400 jd
I broke the 3 point ears off my jd 4400 left side...any tips on where to buy a new housing for the best price?? also any tips on this project..i was told to unbolt the axle housing and it will slide right out as a unit...is this correct or is there any hidden tricks to getting it out??
   / jd 440 rear axle housing replacement?? #2
Try Wengers in Pa. Phone number is 717-866-2130. They salvage tractors and have many Deere parts. They have never failed us. Good luck.
   / jd 440 rear axle housing replacement?? #3
When we had a 4400 we had to replace that housing twice due to broken off ears, it's a real weak spot on those tractors. As I recall, you take off the tire, 3pt linkage, ROPS and fender, then a few little other little things like the brake actuator arm and other little sundry things. Then you unbolt the housing and slide it off. Use a floor jack or something to support it when sliding it off, it's kind of heavy. Then it's just a matter of swapping the axle, gears, etc over to the new housing. I would put a new wheel bearing and seal in while you're at it.
2803 (A50460)
2803 (A50460)
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2015 MACK PINNACLE (A53843)
2015 MACK PINNACLE...
2019 John Deere HPX815E (A50123)
2019 John Deere...
1995 Rinker Captiva 190 (A53473)
1995 Rinker...
