JD 4320 Top Link
   / JD 4320 Top Link #1
Zinno87
Westwood, MA
JD 4320
I want to order a hydraulic top link for my 4320, but I'm a few hours away from my tractor. Does anyone know what the minimum and maximum lengths on the OEM top link are? I was looking at a hydraulic top link that adjusts from 20" to 28".
Thanks
   / JD 4320 Top Link #2
I would think the top link on that tractor would require a longer top link than 28 inches. Carter & Carter lists a 21-32 inch hydraulic top link with pilot valves.
Hydraulic top link, Top-N-Tilt, Side link
My past experience with top and side links without the pilot valves has lead me to the conclusion one should never install a top and side link without the pilot valves. Give Carter a call they can assist you.
   / JD 4320 Top Link
I'm sure that this topic has been beaten to death, but if my hyraulic system is tight, why do I need the check-valves? I don't plan on standing under an implement while it is being held in place with the cylinder. Is there really a chance that the cylinder could slip down that much?
John Deere 5065E 2WD Tractor with Canopy (A55302)
John Deere 5065E...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55302)
2018 John Deere...
ATTENTION! PLEASE READ (A53316)
ATTENTION! PLEASE...
2011 Ford F-350 Versalift 29FT Bucket Truck (A55788)
2011 Ford F-350...
Toyota 8FGU25 (A47477)
