JD 4320 Top Link
   / JD 4320 Top Link #1
Zinno87
Bronze Member
Westwood, MA
JD 4320
I want to order a hydraulic top link for my 4320, but I'm a few hours away from my tractor. Does anyone know what the minimum and maximum lengths on the OEM top link are? I was looking at a hydraulic top link that adjusts from 20" to 28".
   / JD 4320 Top Link #2
I would think the top link on that tractor would require a longer top link than 28 inches. Carter & Carter lists a 21-32 inch hydraulic top link with pilot valves.
Hydraulic top link, Top-N-Tilt, Side link
My past experience with top and side links without the pilot valves has lead me to the conclusion one should never install a top and side link without the pilot valves. Give Carter a call they can assist you.
   / JD 4320 Top Link
I'm sure that this topic has been beaten to death, but if my hyraulic system is tight, why do I need the check-valves? I don't plan on standing under an implement while it is being held in place with the cylinder. Is there really a chance that the cylinder could slip down that much?
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2023 Power Skid Steer Loader (A50322)
2023 Power Skid...
John Deere No. 5 Sickle Bar Mower (A50515)
John Deere No. 5...
