JD 4300 won't crank, but can jump it
   / JD 4300 won't crank, but can jump it #1
samhudson3
Central NC, Southern part of Heaven
John Deere 4300
Hi all,
I see the earlier post from today, my problem is a bit different. Turn the key, nothing happens (no lights either)
but can jump it to start. Got it back to the barn, turned it off, and dead as can be.
I replaced the battery last month (it was 7 years old). Pulled the battery and Advance Auto (where I purchased
it) tested it and it was ok, fully charged. Voltage measured 12.63V.
This is a 1999 4300 HST, 830 blissful hours.
Thanks!
Sam
   / JD 4300 won't crank, but can jump it #2
Sounds to me like the cable terminals need to be cleaned, not picking up the voltage through the build up of crud on them.
   / JD 4300 won't crank, but can jump it #4
Check all 4 battery cable connections especially the negative cable where it attaches to tractor frame.
   / JD 4300 won't crank, but can jump it #5
When checking the cables look where the terminal is crimped to the wire. They can corrode there and be hidden by the shrink tubing. It can drive you crazy.
   / JD 4300 won't crank, but can jump it #6
Led can oxidize so hard a common wire brush won't touch it. I either use a battery brush or scrape with my trusty pocket knife until the gray color leaves and bright silver lead is exposed, then I consider it correct for service.
Hey gang, thanks for the help, problem solved. I checked all the cable connections, they were good. Cables also in good shape, used my pocket knife to clean the cable terminals and reattached to the battery and she fired right up.
   / JD 4300 won't crank, but can jump it #8
Good to hear. Bad enough when they don't even crank, let alone when they don't start after cranking.
   / JD 4300 won't crank, but can jump it #9
Buy yourself a battery cable brush..... and use it occasionally!
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A50397)
2018 Ram 3500...
1982 LeeBoy Motor Grader (A50397)
1982 LeeBoy Motor...
2023 Jeep Grand Cherokee Limited 4x4 SUV (A48082)
2023 Jeep Grand...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
