John Deere 4300 won’t move
   / John Deere 4300 won’t move #1
Smalltimefarmer77
John Deere 4300
Help! Was moving snow with blower yesterday and the roll pin on snowblower broke making the PTO shaft fall off. By the time I got tractor off it had already done the damage. I no longer have a PTO or any gears to move it. Did I take out all the gears when the shaft spun around and hit everything on rear or is there a shear pin inside tractor that is hopefully the issue? If so how do I access it? Can’t find much online yet on this. It’s a JD 4300 9x3 syncshift. It starts and will run but like I said no longer have PTO or any gears. What did I break? Thanks!
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2017 Toro Workman HDX-D Diesel Utility Cart (A59228)
2017 Toro Workman...
(10) UNUSED 1.5" RATCHET STRAPS (A60430)
(10) UNUSED 1.5"...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
