JD 4300 wiring question
/ JD 4300 wiring question #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
Lacking my tech manual still, I wonder if someone can tell me..
Lifting up the seat and messing with the wiring, I found a couple of wires in a plug, connected to nothing. They are orange and yellow, both male and in a recessed plug with a cap snapped over them.
Does anyone know, from my poor description, what these are for?
Thanks,
Bob (who is still studying a solution for "Plug and Play" lighting!) /w3tcompact/icons/smile.gif
/ JD 4300 wiring question #2
Attach something (voltmeter, light, -) to the wires and see if they are hot, or are switched. They are likely the ones you are looking for to 'power on' when the light switch is in the 'D' (or full clockwise) position.
No, the rear work light problem has been solved.. like you guys said.. the purple wire under the seat runs the rear work lights.. and they work as they should now. These orange and yellow wires have no power to them at all with the light switch in any position, although I admit I forgot to try them with the ignition on.
I'll try that tomorrow. I just thought someone might know off the top of their head what these are for, which fuse circuit they are on, etc...
Addendum: these wires also have no power when the ignition is switched on.
I think I need a schematic to figure this out. I will call that number for JD and get my tech manual now! /w3tcompact/icons/smile.gif
/ JD 4300 wiring question #5
I believe the wires would attach to the safety interlock switch for the mid PTO. If you don't have mid PTO, the wires just hang there waiting for you to install one.
<font color=blue>...I believe the wires would attach to the safety interlock switch for the mid PTO. If you don't have mid PTO, the wires just hang there waiting for you to install one.</font color=blue>
Ahah! That makes sense. Yes, we have no mid-PTO. Thanks!
(2) Firestone Tires (A65640)
(2) Firestone...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
1996 Anderson 24' Tilt Trailer (A64126)
1996 Anderson 24'...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
