JD 4300 will not start PTO light stays on
   / JD 4300 will not start PTO light stays on #11
I would like to thank all of those above for this information on the Interlock switch. Clearing brush (cedar trees) in central Texas means running over, under, and backing into trees and piles of brush which from the above has pulled the wires loose on the switch. I shudder to think what JD would charge ...
By the way on the cracked hood: why buy a new one? use fiberglass! The JD green even kind of shows through so no need to paint!
   / JD 4300 will not start PTO light stays on #12
Dale:
I have a 4200 and my shop manual covers your 4300 too. Take a look at these excerpted pages and see if they help you.
Matt
Thanks MATT
You nailed it and I was able to locate the sensor and sure enough it was DOA :cool2:
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A55758)
2 windsor 351...
