JD 4300 that will not turn over with ignition switch
   / JD 4300 that will not turn over with ignition switch #1
PaintGuy
Greenville
John Deere 4300
Hi Folks, I have a JD 4300 that sometimes will not turn over using the ignition switch, starts fine by jumping starter solenoid, sometimes starts fine on its own, wasn't a big problem but the condition seems to be getting worse. I've seen a lot of forums on these tractors not starting do to not getting fuel, etc, but couldn't find one on not turning over. Any help would be greatly appreciated, thanks in advance.
   / JD 4300 that will not turn over with ignition switch #2
You have starter interlock switches for the PTO, HST pedal, range selector, clutch, and or
seat, depending on the trannie your Deere has. That causes most of the problems. Sometimes
an interlock relay is bad or has dirty contacts.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2018 Chevrolet Bolt EV LT Hatchback (A48082)
2018 Chevrolet...
2017 Miller Nitro 6300 Self Propelled Sprayer (A50657)
2017 Miller Nitro...
Poly Tote Tank on Cart (A50860)
Poly Tote Tank on...
2018 Chevrolet 3500 4x4 Crew Cab 3200LB Auto Crane EHC32 Service Truck (A48081)
2018 Chevrolet...
2011 FORD F-450 (A50854)
2011 FORD F-450...
