JD 4300 that will not turn over with ignition switch
   / JD 4300 that will not turn over with ignition switch #1
PaintGuy
Greenville
John Deere 4300
Hi Folks, I have a JD 4300 that sometimes will not turn over using the ignition switch, starts fine by jumping starter solenoid, sometimes starts fine on its own, wasn't a big problem but the condition seems to be getting worse. I've seen a lot of forums on these tractors not starting do to not getting fuel, etc, but couldn't find one on not turning over. Any help would be greatly appreciated, thanks in advance.
   / JD 4300 that will not turn over with ignition switch #2
You have starter interlock switches for the PTO, HST pedal, range selector, clutch, and or
seat, depending on the trannie your Deere has. That causes most of the problems. Sometimes
an interlock relay is bad or has dirty contacts.
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
Trailer Axle (A50860)
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
