JD 4300 SyncReverser Problem
   / JD 4300 SyncReverser Problem #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
When I push the SyncReverser lever forward and leave the clutch out on my tractor it sometimes does not want to move. I have to tap the clutch one more time and it will grab and will then move the tractor forward. I have no problems when pulling the lever back and going in reverse. So, I would like to rule out the clutch being the problem.
   / JD 4300 SyncReverser Problem #2
Sounds like one of the solenoids needs to be adjusted. I think that you would be safe in rule out anything being wrong with a clutch pack.
Where are the solenoids that might need adjusting?
   / JD 4300 SyncReverser Problem #4
I am not sure on the JD without looking at one. They will more than likely be at the end of the shuttle lever.
2005 Cadillac STS Sedan (A48082)
2005 Cadillac STS...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A48081)
2014 Utility...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2022 Forest River Cherokee Grey Wolf 23MK Patriot Edition 29ft. T/A Travel Trailer (A48082)
2022 Forest River...
2013 Ford Explorer SUV (A48082)
2013 Ford Explorer...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
