JD 4300 Replacement Instrument Cluster problem
/ JD 4300 Replacement Instrument Cluster problem #1
jthibodeau89
Shelbyville
JD 4300, Agco Allis 5670
I finally got around to installing the replacement gage cluster for my 1998 Deere 4300 HST and when I started it up the tachometer is sweeping in reverse direction. Idle reading is about 800 rpm, but when i rev up, the needle sweeps down to the zero peg. While I wait for a reply from the seller, I thought I'd post here. Anyone experience this? Can I swap a couple pins in the connector? Thanks in advance for any help.
Sent the gauge cluster back. I purchased another one from a differed source, but it appears to be exactly the same maker as the first (made in India). This one works fine.
/ JD 4300 Replacement Instrument Cluster problem #3
Sounds like the first was incorrectly wired internally.
2013 John Deere 544K Articulated Wheel Loader (A66734)
2013 John Deere...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2013 Kia Soul SUV (A66738)
2013 Kia Soul SUV...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
MF GC2300 fel replaced
