JD 4300 puzzle
   / JD 4300 puzzle #1
Dentbla
John Deere 4300
New member, first post. I have a JD 4300 HST. When I step on forward or reverse pedal, it dies. When I engage rear PTO. it dies. I have bypassed the seat safety switch, I have replaced the switch that is activated by the forward/reverse pedals, and the two neutral safety switches. Fluid levels all good. Now for the fun part...if I pull up on the hand brake, the PTO will engage. If I bypass the forward/reverse pedal switch, the tractor will drive. Cleaned the fuse box area and pulled all fuses/relays out and cleaned terminals. I also switched the relays around as they are all the same, no luck. Front loader works fine and three point hitch raises and lowers.
I am lost for ideas...please help me!
Thanks in advance.
   / JD 4300 puzzle #2
Sounds like the safety circuit is cutting the power to the fuel solenoid. Perhaps a damaged wire? Do you have a manual with the electrical diagrams?
   / JD 4300 puzzle #3
My guess is the wiring to the seat switch is damaged making it open even though you bypassed at the switch.
   / JD 4300 puzzle
Thanks 89, I traced the wiring harness looking for anything questionable, but I guess a damaged wire would be like finding a needle in a haystack. I just have the schematics available on the JD web site. Do you know if the switch on the lever brake is part of the safety circuit?
   / JD 4300 puzzle
Thanks TG, is there a way with a meter to confirm a damaged wire?
   / JD 4300 puzzle #6
Check your private messages
   / JD 4300 puzzle #7
Ill check my manual.
   / JD 4300 puzzle #8
Yes, the parking brake switch is part of the safety circuit. "If trans in neutral, pto disengaged, , then set park brake, operator can leave seat and then re-engage pto." So park brake seitch will allow the ptp to be engaged without operator in seat.
From the manual:
"Engine must stop is pto engaged and operatpr leaves seat"
"Engine must stop if transmission is engaged and operator leaves seat"
It sounds like your sear switch wiring may be the culprit
   / JD 4300 puzzle #9
I had a car I restored years ago with a bad wire for a power window. I gave up trying to find the break and just ran new wires. Still a pain but it did fix it.
   / JD 4300 puzzle
Thanks everyone for sound advice. I got a schematic so will be checking everything this weekend.
2005 Toyota RAV4 SUV (A48082)
2005 Toyota RAV4...
2013 Big Tex 16GP-20 Gooseneck Trailer (A50860)
2013 Big Tex...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
1274 (A50490)
1274 (A50490)
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2012 Tiger 130BBL Vacuum Trailer (A50860)
2012 Tiger 130BBL...
