JD 4300 Problem
   / JD 4300 Problem #1
Dicky
Hi Guys. I just took delivery of a 2001 4300, 430 loader, 60" mmm, turf tires. Here's the problem - I had asked the dealer to make sure the tread was at its widest to give the tractor the most stability for loader work (my property is very hilly). When the tractor arrived, the delivery guy said the mower deck wheels would hit the tractor tires if the tread was wider. I was wondering if anyone else has run into this problem and what the solution is. I asked the dealer if the 72" mower would work. He said he would look into it. Any ideas?
   / JD 4300 Problem #2
If your property is hilly, then the wider deck may not be to your advantage. Sounds like your dealer set the tires at the widest width with the attachments you have. Good luck with the solution. I would have Industrial tires if thinking of much FEL work. Ballast on the rear and not traversing hills with FEL loads works best, IMO.
2004 John Deere 9320 Articulating Tractor (A50860)
2004 John Deere...
2025 20ft. G70 Cargo Transport Chain (A48081)
2025 20ft. G70...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
84in Fork Extensions (A49346)
84in Fork...
2017 Ford F-150 Crew Cab Pickup Truck (A48081)
2017 Ford F-150...
