JD 4300 no start
   / JD 4300 no start
Hmm... 14.2 volts is more than a standard lead acid battery can deliver standing by itself. That's the number I would expect to see on the voltmenter if a charger was attached. You aren't testing the battery, you are testing the charger. Either that, or the voltmeter itself is shot.
To test the battery right, unhook it from the charger, let it set for a day, and then measure the voltage across the terminals. That will tell you whether the battery need replacing.
To find an electrical problem I go: battery, battery cables, safety switches, starter motor, fuses. That takes care of most problems.
rScotty
You're right I did test the voltage while on the charger. The tractor has set for a couple days now so my next move will be to check the voltage. In hindsight I should have checked the voltage before hooking up to the charger. The battery is fairly new and shouldn't be the issue but I will take your advice and start there and work my way down the list. Thanks.
2014 Ford Taurus AWD Sedan (A48082)
2014 Ford Taurus...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A48082)
2022 Forest River...
71053 (A49346)
71053 (A49346)
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2013 Minos-Agri 190B Disc Mower (A50860)
2013 Minos-Agri...
