JD 4300 HST 3 Point not working
   / JD 4300 HST 3 Point not working #1
jmaney
John Deere 4300 HST
I was searching the web and came across this site and just joined. I have a 4300 HST that the 3 point just quit working. There was no indication of any problem, it just quit. I took the implement off and tried raising the empty 3 point arms. I had to throttle up a little bit (maybe 1400 RPM) to get them to raise, but they did come up all of the way. If I stand on the arms, it quits raising. There are no other hydraulic issues, loader and transmission are fine. Any ideas?
   / JD 4300 HST 3 Point not working #2
Welcome to TBN. I know you will enjoy the useful information here. Your question though will probably get more response if you post it in the JD Owning/Operating forum. Lots of 4300 owners there.
John Deere Owning/Operating - TractorByNet.com
   / JD 4300 HST 3 Point not working #3
Welcome to TBN:D
Does your 4300 have a backhoe, or rather to you have the hydraulic hookup for a backhoe on your machine? If you do, I suspect the "loop" connection for the PB (power beyond) has come unplugged just a little. Unplug it all the way, clean up the QD's (quick disconnects) and plug it back in. This is not a uncommon problem.
   / JD 4300 HST 3 Point not working #4
Are you sure that your rockshaft flow control/rate if drop valve is not closed? Knob should be near the seat base on right side.
   / JD 4300 HST 3 Point not working #5
Thread moved to JD Owning/Operating.
2018 PETERBILT 579 DAY CAB (A50505)
2018 PETERBILT 579...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2014 Freightliner 114SD T/A McNeilus 2513 25Yd Rear Loader Garbage Truck (A48081)
2014 Freightliner...
UNUSED Portable Double Bathroom (A50860)
UNUSED Portable...
2009 Mazda 5 Van (A48082)
2009 Mazda 5 Van...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
