JD 4300 HST 3 Point not working
   / JD 4300 HST 3 Point not working #1
jmaney
John Deere 4300 HST
I was searching the web and came across this site and just joined. I have a 4300 HST that the 3 point just quit working. There was no indication of any problem, it just quit. I took the implement off and tried raising the empty 3 point arms. I had to throttle up a little bit (maybe 1400 RPM) to get them to raise, but they did come up all of the way. If I stand on the arms, it quits raising. There are no other hydraulic issues, loader and transmission are fine. Any ideas?
   / JD 4300 HST 3 Point not working #2
Welcome to TBN. I know you will enjoy the useful information here. Your question though will probably get more response if you post it in the JD Owning/Operating forum. Lots of 4300 owners there.
John Deere Owning/Operating - TractorByNet.com
   / JD 4300 HST 3 Point not working #3
Welcome to TBN:D
Does your 4300 have a backhoe, or rather to you have the hydraulic hookup for a backhoe on your machine? If you do, I suspect the "loop" connection for the PB (power beyond) has come unplugged just a little. Unplug it all the way, clean up the QD's (quick disconnects) and plug it back in. This is not a uncommon problem.
   / JD 4300 HST 3 Point not working #4
Are you sure that your rockshaft flow control/rate if drop valve is not closed? Knob should be near the seat base on right side.
   / JD 4300 HST 3 Point not working #5
Thread moved to JD Owning/Operating.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Payment Terms (MUST READ) (A50774)
Payment Terms...
RoGator 844 sprayer (A50490)
RoGator 844...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
