JD 4300 clutch/transmission noise
   / JD 4300 clutch/transmission noise #1
jimmy2960
JD 4300 4WD SRT
2001 JD 4300 SRT 4WD tractor with 750 hours with 420 front end loader and 47 backhoe, purchased 2 weeks ago. I used it to move piles of dirt and debris from timber property that was clear cut in 2017. I used the tractor as a front end loader, not a bulldozer. I worked slowly knowing stumps would be present. I am not removing stumps, but the dirt and debris that was pushed over them when they cleared an area for the logging deck. I have hit a number of stumps over the 10 hours of operation before my failure. AGAIN, these stump strikes were under low power to keep from damaging equipment or operator (me); once located, loader was raised and I went over the stump. The last stump I hit caused the tractor to sound like it was going to fall apart on the very spot. I dumped the bucket and headed for home 1/2 mile away (leaving tractor risked losing tractor). I rode home in mid range gears and the noise the tractor generated was enough to drown out the engine noise. It was a very loud grating, grinding, scraping noise, it was enough noise to make me want to stop, but I had no other way to get it home. The noise only occurs when tractor is in motion, does not occur in neutral (new information below). First impression of noise was a dragging brake. First impression of location was generally under the seat, maybe somewhat forward, very difficult to pinpoint from the seat. The noise reduced by 75% by arrival at barn. No smoke or leaks. Assistant walking beside and around tractor while I drove said sound came from behind engine and in front of steering wheel (location of clutches). I confirmed same location as assistant drove. All 12 forward gears function, all 12 reverse gears work. With rear end raised, the sound does not exist in any gear. On the ground the sound is nearly gone but prevalent as tractor bounces on uneven ground. I would classify the sound as a grinding or grating sound, and from the seat it sounds like it is between the rear wheels. Hydraulic filter was removed and dissected and found to be completely clean, oil was a perfect clear amber, and filled to level in the sight glass. I have loosened the brake turnbuckles (thinking dragging brake) and the sound remains. Applying brakes during sound has no effect. Sound is equal in forward and reverse gears, always when bouncing even on slightly uneven ground. Based on conversations with heavy equipment repairmen, JD service staff, local guy that knows everything about tractors, I am inclined to believe the problem is in the clutches, but involvement of both clutches and lack of debris in filter steers me away from clutches. JD cannot diagnose my tractor for 4 weeks. While moving tractor in and out of barn to access other equipment today, I had opportunity to have the sound continue when tractor stopped moving. Holding brake to keep wheels in the spot where noise occurred I pressed clutch and sound intensified as the pedal reached end of stroke, lessened when released, remained with foot off clutch, and was able to repeat the same several times in that spot before I returned tractor to barn. Have not tried to reproduce that event again, it may have been a fluke since it had not occurred while stopped before. Again, this, in my mind, steers me to clutches. Recent feedback from another forum suggests a problem with input bearing between clutches and engine. This makes sense given sound location and that sound is equal in forward and reverse and occurs when the tractor flexes over uneven ground. Thoughts? Ideas? Suggestions? Experience? Please, phrase any questions or suggestions in layman's terms, I am not a lifelong farmer and tractor owner, but equally, I am not a total novice. Working on the tractor myself does not frighten me, I am mechanically inclined, have the JD technical manual for this tractor and split my smaller (simpler) tractor last year, which boosts my confidence. Thanks in advance, Jimmy.
   / JD 4300 clutch/transmission noise #2
Didn't read if being in/out of 4wd made any difference in sound.
Have you put rear up on blocks to listen and help diagnose where sound is coming from?
Can then roll rear tires back and forth to listen to tranny sounds.
Doesn't "sound" good, but hope it turns out to be easy/cheap fix.
:welcome: to TBN
Event occurred while in 4WD. Noise existed in 4WD, switched out of 4WD for the ride home. With the rear end off the ground, no unexpected sound or feel when engine turns wheels through all gears or when I turn wheels while in neutral.
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
