JD 425 Smoking Heavily
   / JD 425 Smoking Heavily #1
jd425
JD425, 455 and 755
I just picked up what appeared to be fairly well kept JD 425 for right around $2000. when i initially started the motor it spewed thick black smoke and then seemed to level of will normal emissions. Upon getting it home i realized the oil had been over filled by about 1 quart so i drained from the plug and filter. I installed a new JD filter and put in 1.5 quarts of 10w 30 Castrol. Upon starting the engine, it's smoking thick white smoke so heavily i have to wear a face mask running it down the driveway. What could be wrong and what should i check first?
Many thanks from new JD 425 owner.
   / JD 425 Smoking Heavily #2
I'm not a fan of the liquid cooled Kawasaki engines. After running it a while you might want to check the oil level. It seems at times the oil level is increased by added gasoline. I am familiar with a Gator the dealer could not repair ( above problem ) and deere bought it back. Sounds like the tractor was bought at a very fair price. What attachments did it come with ?
No attachments and i've dropped additional $250 in new tires. One thing forgot to mention when i pulled the oil Cap there was a white milky residue inside the tube and around the inside of the Cap. Is this moisture buildup inside the cyclinders? Possibly a blown thermostat and waterpump?
   / JD 425 Smoking Heavily #4
Am wondering why you bought it on just looks ??
Seems a test drive would have been a warning that there was a problem.
How many hours have you put on the engine since the oil/filter change? And did the white exhaust clear up when the engine had a couple hours on it, and did the oil level in the crankcase change any?
Maybe a compression check, and some other evals to focus in on if the engine is bad.
My original 425 had a radiator/oil cooler problem that was a fix under warranty.
Keep a check on the oil level to see that it isn't gaining fluid from either antifreeze or fuel.
Wish you the best finding a solution. Hope someone here can help you find it.
I tested it out and drove it hard for at least 15-20 minutes and nothing out of the norm. It spewed a little black smoke on initial startup until i put the back down and then drove it around the fella's property and everything seemed good. Just my luck, it only started showing these signs after i got it home and fired it up.
   / JD 425 Smoking Heavily #6
You could have engine coolant in the oil from a blown head gasket.
Thanks all for the responses. I'm gonna work on her today and let you know what we find.
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
