JD 425 Smoking Heavily
   / JD 425 Smoking Heavily #1
jd425
JD425, 455 and 755
I just picked up what appeared to be fairly well kept JD 425 for right around $2000. when i initially started the motor it spewed thick black smoke and then seemed to level of will normal emissions. Upon getting it home i realized the oil had been over filled by about 1 quart so i drained from the plug and filter. I installed a new JD filter and put in 1.5 quarts of 10w 30 Castrol. Upon starting the engine, it's smoking thick white smoke so heavily i have to wear a face mask running it down the driveway. What could be wrong and what should i check first?
Many thanks from new JD 425 owner.
   / JD 425 Smoking Heavily #2
I'm not a fan of the liquid cooled Kawasaki engines. After running it a while you might want to check the oil level. It seems at times the oil level is increased by added gasoline. I am familiar with a Gator the dealer could not repair ( above problem ) and deere bought it back. Sounds like the tractor was bought at a very fair price. What attachments did it come with ?
No attachments and i've dropped additional $250 in new tires. One thing forgot to mention when i pulled the oil Cap there was a white milky residue inside the tube and around the inside of the Cap. Is this moisture buildup inside the cyclinders? Possibly a blown thermostat and waterpump?
   / JD 425 Smoking Heavily #4
Am wondering why you bought it on just looks ??
Seems a test drive would have been a warning that there was a problem.
How many hours have you put on the engine since the oil/filter change? And did the white exhaust clear up when the engine had a couple hours on it, and did the oil level in the crankcase change any?
Maybe a compression check, and some other evals to focus in on if the engine is bad.
My original 425 had a radiator/oil cooler problem that was a fix under warranty.
Keep a check on the oil level to see that it isn't gaining fluid from either antifreeze or fuel.
Wish you the best finding a solution. Hope someone here can help you find it.
I tested it out and drove it hard for at least 15-20 minutes and nothing out of the norm. It spewed a little black smoke on initial startup until i put the back down and then drove it around the fella's property and everything seemed good. Just my luck, it only started showing these signs after i got it home and fired it up.
   / JD 425 Smoking Heavily #6
You could have engine coolant in the oil from a blown head gasket.
Thanks all for the responses. I'm gonna work on her today and let you know what we find.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1271 (A50490)
1271 (A50490)
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
